Main cabinet is not heating up to set tempt. i.e. set at 120 F, tempt only at 92 F
Mon Sep 27 2021
Main cabinet not heating up
Wed Sep 29 2021Reply from Jackie653
Main cabinet has 2 heating elements and fans in it, one at the top and one at the bottom of main cabinet. have you verified that both these are functioning properly? could be one of them failed.
Thu Sep 30 2021Reply from Chris S
I would agree with Jackie to check the both heating elements and fans. If one has failed, I would suggest replacing both as the other is sure to follow. Replace both the fan and heating element preventatively even if one is still functioning.
