Thu Sep 30 2021
Service login credentials
I know the windows service user name and password, user: crservice, pass: Agsrvc2ls And I can log into windows using these credentials, but when in " NX service and configuration tool" I try to "Service log in" from "Security" menu and it asks for user name and password which I do not have handy, would you please help me? Also when I try to open the scanner's web page by typing its IP address in a web browser it asks me for user name and password which I don't have, would you please provide me with this info?
Thu Sep 30 2021Reply from MedWrench Crystalyn
Thu Sep 30 2021Reply from Luis_Med
What CR  do you have ?
Thu Sep 30 2021Reply from Osama Sandouk
It is AGFA CR15-X
You can try admin/admin. What is the reason that you want to go there?
Already tried admin/admin but did not work.
The unit does not work and red light on the scanner is always lit, looking in the error messages found the print queue full and needs to be emptied, refering to the service manual I found the solution is to do a "service login" from the service application menu and purge the full queue from there, or log into the scanner's wen page from a web browser, but both required authentication (user name and password).
I can share a troubleshooting guide with you. I will check if I can find the correct password.
Tue Oct 05 2021Reply from Osama Sandouk
Well Luis would you please send me the troubleshooting guide for this unit on my email: osandouk@gmail.com.
Thank you...
Wed Dec 08 2021Reply from RamiAY
Hi Luis_Med, Hi Osama
Could you please share me the service login  username and password?
My mail is rami.ayoub@technostar.biz
Kind Regards
Thu Feb 15 2024Reply from Mariusz Spider
Luis_Med or Osama Sandouk would you please send me the troubleshooting guide. I have the same problem. My email: mkochan@spider.com.pl
Thank you
Mon Aug 12 2024Reply from ivanmike
user: mega
passw: adonis
