toshiba aquillion 65, there was a power failure and communication with the couch was lost. ERROR "the system has failed to obtain couch position informatio. Select Confirm to retry". The couch with buttons on the computer tamograph works without problems. Before the power failure, the computer tamograph worked fine. Perhaps some controller is out of order, but which one?
Sun Oct 03 2021
Mon Oct 04 2021Reply from BMET-KY
Check the GTS board it is on the right side of the gantry. You can teraterm into it to check for errors. You could also check under the plate that is inbetween the gantry and couch. There is a small power supply under it that I have had fail.
Tue Jul 05 2022Reply from Gregg Reyes
Mon Oct 10 2022Reply from Emily Vitkovitsky
