Tue Oct 05 2021
Pressure test error
Pls when I'm doing functional test on the machine I receive the following error code 124 pls how do I rectify the problem
   RE: Hemodialysis Unit Report Post
Tue Oct 05 2021Reply from MedWrench Crystalyn
Tue Oct 05 2021Reply from Idmohd74
The name of the manufacturer is GAMBRO.
Model: AK98
It's a dialysis machine.
Thu May 26 2022Reply from Puvlo
Can you tell me the full error code and name. You can find it on functions, maintenance, error list.
Fri Apr 04 2025Reply from colinruud
Error code 124 is a technical error, but without knowing more, I can simply suggest that from the service screen, you can access calibrations. Go to other, and calibrate the variable flow. It seems a cure all for a lot of what ails this machine.
