Flouro Boost not working after SRAM replacement
Hi Curtis,
There is a possibility that Boost is disabled in new SRAM.
Please Access Mainframe Menu and find out if Boost is enabled or not.
Good Luck,
ACCESSING THE MAINFRAME MENU
1. With the system powered on, insert the OEC access disk into the floppy drive at
the rear of the Workstation.
2. Press the SETUP OPTIONS key on the Workstation.
3. Use the cursor control keys (or trackpad) to highlight the Access Level 2 (Service)
sub-menu and press ENTER (or superkey).
4. Select Access Mainframe Menu. When this option is selected, the following menu
appears on the left monitor.
K. (RUN) MAIN
Use this option to start the generator application software when the desired parameters
have been selected. This parameters appear on this same line.A. Is boost available [Y/N]? Y
B. Is X-ray Inhibit line active low [Y/N]? Y
C. Fluoro Beeper ON [Y/N]? Y
D. Video Level set at: 450
E. Percent of maximum available boost: 90
F. Fluoro timer set for [5-10] minutes 5
G. Boosted Pulse Available [Y/N]? Y
H. Film shots allowed on boost button only [Y/N]? N
I. Pulse Video Level set at: 315
J. Video level dead band: 16
K. Boost time: 30
L. Default ABS Tables: DOMESTIC 1
Please tip me in doing sram formating and reloading from the backup floppy disk.
I finally got old computer not functional yet for this job but has only PCMCIA port "Dell latitude c800"
there is no floppy disk that can fit this computer, i am thinking of using flush drive, is that okay?
Any consideration i have to follow for this.
I checked the service manual for this issue, and there are some things i didn't get.
This is my first time that is why, just what you think and experience is what i am looking for sir.
Thank you,
Nebiyu
Fellow eng practising imaging.
