Getting an E0001 on an Omega ST Autoclave. What does it indicate the problem is?
Thank you
Wed Oct 13 2021
Error Codes
Thu Dec 15 2022Reply from OmegaRob
I've never seen one, but I just was asked if I could get a gasket for one. It looks like a knock off of a Ritter M-11. The 0001 error code on a Ritter is a power failure, often caused by losing water and overheating. The overheat thermostat kills the line voltage coming into the unit and then when it resets, you get the 01 error.
