Wed Oct 20 2021
DATABASE ERROR
Hi , i am seeing this error repeatedly on hologic ammography model selenia "The aquisition data base error is corupted. the system may have shutdown incorrectly" i will be very thankful if someone help me regards
   RE: Mammography Report Post
Wed Oct 20 2021Reply from Seungil
I am not sure it is the same issue I had, but if you performed clear database recently (after 2020) on solaris machine, the database error will be shown.
I seems a kind of software bug.
I believe it will be fixed as restoring software or replacing HDD.
Wed Oct 20 2021Reply from Jodiflo
Jodiflo
You may need to restore the database if it is correct. But this will require a copy of the database from before the corruption occurred.
Jodi Andrews - Official MedWrench Guru
Thu Oct 21 2021Reply from Service Mammo
Sun Oct 31 2021Reply from Juan2011
Mon Oct 23 2023Reply from Cano
Did you fix it? I’m having the same error.
c_cano@outlook.com
