Good afternoon. The device gives an error E82 and E84 when changing attachments. If the device is loaded with the attached attachment, then only the ET manipulator works without errors. Recently, the power supply was repaired (the diode exploded and 2 power keys were punched, respectively, the fuse), after repair it worked normally for two weeks. What could be the cause of the malfunction? Thank you for the attention)
Tue Oct 26 2021
The device gives an error E82 E84
Tue Oct 26 2021Reply from MedWrench Crystalyn
Tue Oct 26 2021Reply from AlexVidnova
burnt out 40N25 keys were replaced with IRF4242, only one pair. Maybe that's the problem, although it worked fine for 2 weeks. With a pulse, both capacitors are used, maybe one is not pumped to the desired values?
