System on, monitor and touchscreen dark
Do you hear the fans running and the system try to turn? Is anything displayed on LCD and touchscreen during boot up? If it seems to turn on but just no displays I would look into the GPU, motherboard, or maybe software. The motherboard is on the right side. You could try pulling it out and reseat ram and GPU. If that doesn't work pull hdd and run check disk and disk tests from another pc if you can to see if it may be failing anything.
Hello BMET,
Yeah the fans are running, but the monitor, and the touchscreen do not turn up as well as the operating panel. Thank you for the leads, I'll look into them next week. But to be able reach the board, I need to know the procedure. Could you share the complete service manual (the version we got here only has part 1 and 2) if you happen to have it?
Thanks,
Yakhouba
