CORE Touch Screen Cal?
RE: Arthroscopy Systems Report Post
press the dot . do same for each dot that appears. when dots appear in all quadrants, press the red CORE box .
unit will then complete the boot sequence.
Hello, how did you get to that point? I'm trying to calibrate the touch screen of a Core 2 but I can't find the way, maybe it's the same as Core
with power OFF. press and hold anywhere on screen and apply power .
release when calibration screen appears . then press anywhere on screen within 10 sec to enter calibration mode.
Thank you very much! It worked good with Core device but unfortunately doesn't work with Core 2...
Core 2 turn on core and press on bottom right corner of screen much like with the pnuemo XL insufflator. If done right should take you to the screen Cal immediately and all you have to do is hit the squares
