error 10391
Of course, if you describe the solution step by step and as clearly as possible, but there are cases in which specialized accessories such as a call or video call are needed and unfortunately by this means the problem can not be solved, in the same way we are happy to provide support and support to those who need it.
Hello / i have model cr ir 346 ru the problem software work but very slow can you any them support me thank you
