Fri Nov 19 2021
Open door alarms beeping
open door alarm won't stop even when the door are closed. it's a sorvall RC6 any advice? How to open the door? I turned it off and turned on still cant open door.
   RE: Centrifuge Report Post
Fri Nov 19 2021Reply from Chris-CBET
Chris-CBET
Should be a screw on the front cover,  towards the bottom.  Remove the front cover and you'll have access to the door lock mechanism
Chris-CBET
Fri Nov 19 2021Reply from Navs
Thank you
Thank you
Thank you
Thank you
Thank you
Thank you
