Mon Nov 22 2021
Fails volume accuracy test by -18.66%
What repair needs to be done in order to fix a severely failing volume accuracy test? I replaced the Logic Board and Motor Controller Board. The 8100 is still only infusing 9.77g out of the programmed 12.0g. Should I replace the Motor? Pressure Sensors? Not much left after those...
   RE: Infusion Pump Report Post
Mon Nov 22 2021Reply from BMETSlayer21
Mon Nov 22 2021Reply from Mark McGowan
I personally would have started out with going into the calibration mode to calibrate the flow and also the sensors.  If you could not get either to calibrate then I would have replaced the bottle/patient side pressure sensors.  This has resolved the issue for me in the past.
Not that I have not seen a motor be the issue, 9 times out of 10 it will not be the motor.  It will be a combination of the pressure sensors and possibly the AIL sensor.  I know, the AIL sensor has nothing to do with correct flow of the fluid, it has to do with air in-line.  But I have had to replace it after trying the pressure sensors.  Only once did I ever have to replace a controller board for flow accuracy.
Mark M
BMETSlayer21
Thanks! So far, I replaced the AIL Sensor Assy. and it changed nothing. Replacing Upstream Occlusion Sensor, now...I'll uodate to let you know what the fix was.
Make sure that you recalibrate the pressure sensors and the flow through the calibration portion of the Alaris SW.
BMETSlayer21
Oh, that goes without saying. Thanks for the reminder!
Mon Feb 21 2022Reply from RZamudio
RZamudio
If the volume accuracy will not calibrate, check for cracks in the bezel posts where the drive assembly mounts (6 posts that the assebly screws into). The loose drive assembly causes the infused amounts to wander, even after calibration.
