OEC - How to Reset Image Rotation?
Would you please comment on how I can get to the operator's menu? Is that possible after I start taking fluoro? Thanks.
To access Setup features, press the Setup key on the Workstation keyboard.
Select C-arm last button on the right side,
Set defaults
To set the default position for camera rotation, collimator rotation, collimator iris and leaf position and magnification:
1. Select Home or Retain Last for the default position.
Home returns the camera and collimator to the home position, opens the collimator iris and/or leaves to a fully open position, and returns magnification to normal.
Retain Last keeps the same settings for the next patient exam or at start-up.
2. Select OK to close the C-arm screen and return to the Setup screen.
3. Select Exit to close the Setup screen.
Key there is the New Exam so it will not change in the middle of an exam.
