Wed Dec 01 2021
Many IV pumps with same error
Clean Load port # 2. I have many pumps that go down with this error. Any suggestions. Thank you Andy
   RE: Infusion Pump Report Post
Wed Dec 01 2021Reply from Chris S
Chris S
Baxter's suggestion is to clean load point 2 with a cotton swab and distilled water.  This doesn't seem to work very often.
The part that is usually replaced when I send these pumps to Baxter or 3rd party companies is the ultrasonic sensor (Part number 35711-S-988).  I haven't been able to find this part for sale anywhere.
Thu Jun 09 2022Reply from Matt O
Depending on the software version of your pumps there is also a calibration procedure that I have had some success with.  It requires a different service passcode.  You'll know if your software will allow you to calibrate if the pump takes the password.  If it doesn't, your software is not the right version and you'll most likely have to send the pump in for repair.  The other password is 8961.
Mon Jul 17 2023Reply from hartfighting
A separate service PIN is needed for this.  Pump acceptance of the password will indicate whether or not your program supports calibration. It doesn't appear like this is very effective.
drift boss
Mon Jul 17 2023Reply from amusedthrushe
This requires a different service PIN.  Whether your program enables calibration will be shown by the pump's acceptance of the password. This doesn't seem to be working all that well.
scratch games online
