Hello, I am a biomed and working on a Skytron Hercules 6500 hd table. When hitting the kidney down button, the leg section goes up. any thoughts on possible cause?
Thu Dec 02 2021
Kidney up position
Thu Dec 02 2021Reply from Chris-CBET
Are you using the remote exclusively? I'd remove the remote and use the base control switches if yours has them. If that doesn't help, disconnect them and try the hand control again, after that look at the your control board for anythign causing a short
Mon Dec 20 2021Reply from buckley
