Tue Dec 07 2021
Error help!!
Waveform acquisition error
Wed Dec 08 2021Reply from T-Lobato
T-Lobato
Page 1-64 of the service manual:
Problem: Waveform Acquisition Failure
Reason:
-Front End Failure
-External Supply Failure-+12/-23 Volt Board Failure
-CPU Board Failure -CO2 Interface Board Failure (optional)
Solution:
-Replace Front End Board.
-Check External Supply Output voltage.
-Replace F1 fuse on +12/-23 Volt Board. -Replace CPU Board.
-Replace CO2 Interface Board
Seems like a good place to start.
TJ Lobato | MedWrench Guru
