Good afternoon, I need help urgently. The bio security cabinet Bioquell Microflow Class 2 displays the following message: Fan 100%, Battery Fail. I found an open fan fuse and already replaced it, now the fan works as soon as it is connected to power. I think the internal battery on the main board will need to be replaced. I don't know if I am correct and if after that I should go into some mode to clean up the error. Thank you.
Sat Dec 18 2021
Battery fail message. Please help.
Mon Oct 24 2022Reply from Mohibrabiomed
Hai,
Regarding this issue i need your help.because we are also facing some issue in our safety cabinet.so it will be great helpful if you can share the way how did you solve this?
