Tue Dec 28 2021
X2 port - trying to get data out into PC...
service/communications/Computer If is showing 'Closed'. Am I missing a bit of hardware or is this a configuration thing - and if so, how can I fix it please?
Mon Jan 03 2022Reply from MedWrench Crystalyn
Mon Jan 03 2022Reply from Rob Sneyd
Datex Cardiocap/5. Thanks for getting back to me. I'm trying to get data out for a research project. Currently trying to test the demo version of medicollector but it cannot see the monitor.. No joy. In the Cardiocap/5 service menu when I burrow down to 'communication' then 'Computer If' I get 'Interface status CLOSED'. the Technical Manual implies ' CLOSED indicates that the necessary hardware is not present' is this really true? what hardware? or is it some software thing that I need to toggle. Alternatively, on the graphical trends I can (painfully) read off data every 10sec by using the 20min scale and the cursor. In contrast the tabular trends seems to be set at 5min with no way to configure it. Any ideas? For the project I want to read off gas bench concentrations for 5min in as much detail as possible
Thu Mar 03 2022Reply from Rob Sneyd
great progress, i got (bought) the right cable from
https://www.medicollector.com/support-compatible-devices.html
crazy expensive software (didn'tbuy it) but it works in domo-mode  (with the right cables…)
and this amazing  free software  from Korea  https://vitaldb.net/vital-recorder/
so i'm using the US cable with the Korean software.
so far, so good, great stream of O2 and CO2 waveforms but the nitrous is damped. Any ideas? (I am making a separate post)
Fri May 20 2022Reply from MacDaddy
Hi Rob! I have been also wondering how I can mirror the information from the monitor to an external montior in the operating room. I'm glad I found your post.
Can you use any serial cable off Amazon or does it have to be from MediCollector?  Have you tried different serial cables besides the Medicollector work with the Korean software?
I want to also try a serial cable to usb-c to extract data to a more modern laptop.
