Hi! I have this pump and it keeps giving me the distal air error I already modified the pot for the distal sensor but it keeps popping up the alarm, any advice?
Thank you
Thu Dec 30 2021
Sensor
Thu Dec 30 2021Reply from JPRV29
In case anyone need it, you can check the pot called DA on the card, move it, I used 100 ohms and it worked, I just double check it with distal air on purpose and it works good. :)
In case anyone need it, you can check the pot called DA on the card, move it, I used 80 ohms and it worked, I just double check it with distal air on purpose and it works good. :)
Mon Jan 03 2022Reply from MedWrench Crystalyn
Mon Jan 03 2022Reply from JPRV29
Wed Nov 23 2022Reply from Dave Lester
If anyone needs it, you can verify the DA pot on the card by moving it. I used 80 ohms, and it worked. I then purposefully double checked it with distal air, and it functions properly.
word hurdle
