I have following error when starting patient
Invalid vedio capture device is selected
Open image source and activate valid one
After press ok. I have selected firewire PAL
Now i can see image on the screen.
Next error showing after pressing capture button on scope
DF is not connected E402
Connect DF.
Please let me know how to solve this issue..
Thu Jan 13 2022
Endobase error
Wed Feb 01 2023Reply from tylerdeveera
Hi Swami,
Did you ever figure out the issue that was causing the E302 Connect DF error? I am having the same error now when trying to capture an image.
Let me know, thank you.
Fri Aug 25 2023Reply from Quest Medical Equipment
Has anyone solved the "DF not connected E402 error code"? My customer is using an Olympus OEP-5 printer and is not using the internal image management system to capture pictures from the OTVS-190 with a flash stick. I can't find anything online.
