Can the Optima CT660 64 slice be upgrade to 128 slice? What is the difference between CT Scan 64 row and 64 slice?
Thu Dec 16 2010
Upgrade 64 to 128 slice
Mon Dec 20 2010Reply from GaryBiomed
I believe the function of this unit is to provide a higher quality at a lower power consumption. So it can do the work of a 128 or higher slice with only 64, in theory.
Here's one part from the brochure, "the Volume Helical Shuttle application helps you to cover the area equivalent to a 500
slice CT scanner"
You may have to contact GE for upgrading info & pricing.
