Nothing is melting but it emits a kind of ozone or electrical discharge smell is the best i can explain. Whether it is plugged in or not it still does it. Any ideas out there...??
Sat Feb 05 2022
75 evo emits electrical charged odour.
Sun Feb 06 2022Reply from Chris-CBET
Cleaning solutions being used may have seeped in and are causing corrosion to pcbs. Inspect the wiring and control boards. Look for signs of liquid damage/corrosion. If the room its in is humid that would also cause the problem
Mon Feb 07 2022Reply from Rix
Most likely the motor capacitors for the lift motor inside the base. There are typically two of them, one above the other. When they degrade, the overheat and emit a foul "electronic" odor. When you remove the front panel, you may see oil leakage or hear sizzling if operating the base up or down.
