Sun Feb 13 2022
X ray disabled 24 hrs recharge required
(&&.) request my service as a radiographer , when I turn on the unit this message above was the first thing that appears , as a radiographer I know how to operate in general the C arm unit , but I dont know the particularities of all of them , can you tell me what to do ?
Sun Feb 13 2022Reply from jrreyes
jrreyes
That message appears when the batteries are weak. Usually plugging in the work station to the wall and connected to the Carm(ensure the green light by the key is turned on) and leave charging over night will resolve the issue. If not most likely the batteries in the Carm are bad.
Mon Feb 14 2022Reply from C12Guy
C12Guy
Jrreyes is correct. Leave the system plugged in with the interconnect cable connected. If the battereis are around 3 years old I would look into getting them replaced. C-Arm batteries & charger
Use this test to determine if the C-Arm’s battery packs and charger are performing adequately.
WARNING: The following procedures generate X-rays. Take appropriate precautions before
performing the following tests. Use the appropriate PPE to protect yourself from
X-ray exposure.
1. Select Film mode and set the technique for 75 kVp @ 200 mA.
2. Make an exposure and verify that none of the following messages are displayed:
l X-ray Overtime
l kVp Error
l mA Error
3. With the C-Arm’s Battery Charger covers removed, make an exposure and verify that the red
LED bar graph located on the Battery Charger PCB indicates 170 to 190 volts during the shot.
If below 165 you need new battereis, also could be the battery charger and or facility power.
C12Guy
X-ray exposure.
l X-ray Overtime
l kVp Error
l mA Error
