NBP Auto Print
Can you turn the recorder off in the configuration? Go to wrench icon -> System Admin (215 or facility defined password) -> Diagnostiics -> Maintenance (129) -> Configuration.
Can recorder be unchecked from this screen? I don't have any with recorders, so I can't verify if this works.
I also thought of turning off the recorder in configuration, however I don't have an attached recorder so that option was greyed out. Turns out copying the settings from another VS3 that had NBP Auto Print unchecked resolved this issue. Export the settings from another VS3 and importing the settings via flahsdrive did the trick. Philip from Philips tech support helped me with this. Thanks for your quick reply Chris S.!
