Block 5 sensor error x000D0015
RE: Biotech/Life Science Report Post
OK, me comunica no e-mail para te enviar as informações que precisa sidneisantos_22@hotmail.com
1. Log in as a service. On the main screen, tap Tools.
2. On the Tools screen, select and tap Sensor Data.
go back and run a race, then go back to sensor data and check sensor 5 if the temperature will be different from the 4 sensors.
measuring the sensor it may be fine, but when the temperature changes the sensor may not read the correct temperature
Thank you very much,
I will check the sensor information to see which temp sensor is not performing properly. My thought is that once I get an idea as to which sensor is bad I may try using a heat gun to warm the sensor to see if the resistance changes properly. Otherwise my concern is that there is a problem with the main board signal processing.
I will post what I find.
Thanks again,
Merlin
Now for the really dumb question!
What is the factory Service Password for the Bio Rad C1000?
The lab has never used the service section of the instrument and no one knows what it is.
Thanks for your help.
Merlin
