Thu Mar 24 2022
Thermo Shandon Cryotome E - P5 error
Thermo Shandon Cryotome E (620E). Does anyone know what the P5 error code indicates? It was in the micron setting window. I'm not sure it's an error, but I don't know what it indicates.
   RE: Microtome Report Post
Tue May 03 2022Reply from Paul Moyer
P = the temperature of the Peltier load heatsink in the Electronics Unit. This should change to reflect the action of the Peltier in the Cryobar when [CRYOBAR BOOST] is pressed. If no change in temperature registers then there is a fault in the Peltier or the connections to it.
F: 5 A fault in the Peltier Load heatsink temperature probe
