The Hi Low function does not work. THe relays click though no response from either motor. "When one goes is the other bad as well"?
Mon Mar 28 2022
No Hi low function
Tue Mar 29 2022Reply from Stanislav_
Hey! check the connected drives or the condition of the fuses (the control box is under the couch). If it is old, then check the relay or the limit switch for the state of the rise or bottom is faulty. (witemonah@mail.ru)
Tue Mar 29 2022Reply from Chris S
If one column fails, neither will work to raise or lower the bed. Try the trendelenburg/reverse trendelenburg function. If one works but not the other, that will tell you which column is bad
