Learning Solutions - Computer-Based Training CD
RE: CT Scanner Report Post
Tim,
Do you have a local distributor for GE CT scanners? If not, what region are you in? Your best bet is getting in touch with them and asking for a copy. I can try and help you find a distributor if there's not one you normally use.
Koby Kenney
MedWrench Guru
Tim,
Koby Kenney
MedWrench Guru
I may know someone with documentation and materials for study on this model. Email me asking for this at contact@austinlyon.net
