Power button is not working
Philips had a big issue with those VS3 power switches a long time ago. They had a program that if you contacted Philips with the model and serial number, they'd send a box of 5 of the rubber switch sets to you. The power switch is part of the other buttons except for the knob encoder. So you end up replacing all the membrane switches at the same time.
It looks like Philips has a FCO on this part. You *might *be able
to get it replaced for free if you mention Field Change Order: FCO86201022A.
Philips pn: 4535 641 01891
latest pn: 4535 642 42221
Good luck.
Do you have to be a vendor or anything I originally bought it for taking care of a family member? Will they help anyone that calls? Is it easy to replace the Philips VS3 SureSigns Membrane Switch?
I appreciate the help
-Kevin
They should be able to help you. Be prepared to give them the serial number which they will use to see who they originally sold it to. Try calling PartsSource if things with Philips do not work out.
Is it easy? It should not be if you have experience taking devices apart and re-assembling them. If not, you should consider sending it to a vendor.
T.
TJ Lobato | MedWrench Guru
There is a problem that I found with an extremely low battery. The watchdog feature will "lock out" the power button, until you remove the battery and unplug the power cord. Then re-insert the battery and plug into AC power .The device will restart, and the power button will work. You will then have to reset the date and time. The battery will be very low so plan to plug it into AC power for 2 to 4 hours to recharge.
So can I do that process that the battery is charged? Can you list the steps again for the lockout for the philips suresign vs3?
Really appreciate your help. The monitor is not relatively charged so what should I do ? Do I take the battery out when its plugged into the wall?
1) unplug the device from AC power
2) open the battery compartment door
3) remove the battery
4) re-insert the battery
5) plug back into AC power
6) unit is now active and the date and time will need to be set correctly
Hope this helps
