EnVisor access to disk drives
Only insert a video card that is supported by COTS, the program will check the registry entries. It can be solved with other video cards, but I don't recommend it to you. You need expert. Don't take out phgshell, that's not important. Add the registry a new line:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run ->
""blabla"" %windir%\system32\cmd.exe
If the machine run, at the command prompt you type: explorer
There is a "diskaccess.exe" somewhere, which gives you write access to the disk.
Only change anything if you know what you're doing!
Hello.
I've managed to install all missing drivers. Since I didn't have COTS supported VGA card now, I have used onboard Intel. Everything worked ok (2D, Color, PW....) but I get errors like "reporting module is not started yet" or measuring is not possible now because "ultrasound.exe", only when run. Because of that I restore good working image from few years ago. Now I still getting same error?! and this one after starting application: "You must run and pass the video test before you may run this application"
Is that all because of unsupported graphic card by COTS?
This is an older thread but There is an easier way to do this, let me know if you still need help with this.
