Wed May 11 2022
Fuga en Interruptor Principal / Main Switch Leak
¿Alguien ha tenido problema con fuga en el interruptor principal? Al accionarse se escucha un pequeño ruido que al parecer es fuga de oxigeno. / Has anyone had a problem with the main switch leaking? When you activate, a small noise is heard that apparently is oxygen leakage.
Sat May 14 2022Reply from michael1234
michael1234
E necesar cambiar imediatamente el interruptor para nao danificar outros circuitos e componentes.
michael1234
