Shut down
Most common failure in x300 is the dc/dc power supply. Most likely it's cause of your issue.
Hi, most of problems of Siemens x300 that is power supply. DC\DC has problem with hight voltage +-100v. Check please after message will appear on your monitor.
I know what microchip need to change.
If you will need more info, write me on email
We appreciate your participation and hope that the MedWrench forums will help you to solve your medical equipment issue
good afternoon. I had such a problem. I replaced the npn (80v) transistor on the board ( orchid ) it is designated as q1 and the zener diode zd 1. the problem is solved.
