run system set-up
Are you connecting to an existing server that is already configured? If so here are the steps:
If you are not logged on as SupportUser and must run PIIC iX System Setup,
1 Press and hold the Shift key and right-click the PIIC iX System Setup shortcut on the desktop.
2 Select Run as different user in the list.
3 Enter SupportUser as the User name and the appropriate Password in the Windows Security dialog. Then click OK.
4 Enter the local service user and password in the Access to PIIC iX System Setup dialog. Then click OK. System Setup presents its first screen
System Information
System Information is typically the first PIIC iX System Setup screen and permits changing Computer Name and Monitoring IP. Screens that appear depend on the system you are installing.
1 If you want to change Computer Name click the adjacent Change button, and do the following.
- a Enter the desired name in the text box, then click OK. A message appears.
- b Click Yes in the message dialog. Important Any change to computer name requires a system restart. Do this immediately rather than progress through System Setup if your system relies on DNS. You must immediately restart your host so that you can connect to the primary server.
2 If you want to change the Monitoring IP Address or configure the network adapter, click the adjacent Change button to open the Network Connections window. The Network Connections window opens.
Language Selection
1 To choose desired language settings in the Language Selection screen select desired language from the drop-down list for Clinical Language, Service Language and Regional Settings.
Database Installation 4
In the Database Installation screen click Install. A progress bar appears. When databases are successfully installed the message, Databases installed successfully appears. Click Next > to continue.
Connect to Server
1 In the Connect to Server page specify which device is the Primary Server, the server on which the Configuration database resides: This host (for Local PIIC iX Small Network PIIC iX, or Enterprise iX Primary Server), Other host (to connect to a Primary Server that has the Configuration database). If you are connecting to Other Host a login dialog will permit entering the appropriate User Name and Password. If this is the case enter appropriate credentials in the Login dialog, then click OK. If the host is not currently part of the Primary Server topology, a dialog will open that will permit you to add the host.
If your PIIC iX is connecting to a Primary Server and the Server has already configured the system topology, it will receive its configuration from the Primary Server. Otherwise, you must run PIIC iX System Configuration locally (page 6-3).
2 Click Next > in the Connect to Server screen to continue.
From this point you basically keep clicking next and following the prompts. Assuming the PIIC IX is already licensed and was previously set up. If not, there are many more steps involved.
