is this website still operatinhm
RE: Microscope-Surgical Report Post
Hi Oppie,
Unfortunately, that model has been discontinued for quite some time. I doubt you’ll find anything but parts machines and the old sales brochure online.
I work for the company that made the power supply for zeiss and offer the schematic if anybody is interested.
Tried to find a way to upload a pdf and finally gave up.
We - Ludl electronic Products (LEP) took in a repair of one of our slitlamp power supply and owner Also included the microscope. Problem appeared to be in the scope with the brightness control that should measure 100 ohms at minimum brightness and 0 ohms for full output.
If you would like to share with the MedWrench community, please click HERE and we will upload it to the product page on your behalf.
I just bought a used one and I'm gonna try to revive it. No power supply.. supplied, but I should be fine I think.
Need help on how to open up the "light box" or conytroller box; the lowest knobs, the ones for adjusting slit height, need service badly.
Hey from Sweden! //Ric
To the original poster, what do you need? The customer manual is available online, the service manual not so much.
What do you guys use for cleaning these things? Alcohol?
My unit is in overall good shape lens wise, except for a beamsplitter that has an old angled camera adapter for a 35mm housing. The mirror inside the camera adapter is really dusty, so I was thinking alcohol and cotton swabs.
I uploaded a schematic for the power supply of the 30 sl/m system. Find it in the files section.
I have no specifics on the optical system as our involvement was only as a subcontractor to zeiss USA.
Lamp is a 30 watt tungsten halogen.
Intensity control is a 100 ohm variable resistor that is part Of the optical system.
On the repair we just took In, I mounted a new control near front panel meter of power unit. Then disconnected the external control.
That's a great resource, I found some wiring from the slit lamp head leading down in the hollow swing arm shaft, ending in a socket not connected to nothing. The schematics can probably tell me more, but I am guessing it was supposed to power one of the many additional modules available at the time.
Service tip: the slit height knob mechanism had seized up and was veery sluggish, to the point of me using so much force to move it that the axle started loosening and starting to wobble, and I was afraid something was broken.
After taking away the chin rest from the bottom plate I was better able to access the underside of the light control box, and there's a service hatch of sorts. Remove two screws and you can access the slit height adjustment, and with a drop of Teflon Oil (Gun oil) on a screwdriver I was able to lubricate the mechanism. Good as new! Almost.
