Error of xario xg
Try clearing your Job Status first. You may also want to rebuild your database, this will delete all files and pictures that are lost that never got to your PACS (if you have one). A database rebuilt should be done at least 1 time per year or during your Preventive Maintenances. If you need the procedure for this, you can email me at mariolm69@hotmail.com or you can probably find it here on Medwrench since I have already posted it several times, this is the same procedure as Aplio 80, Aplio XG, Xario and Xario XG
Hi, I know how to solve that problem)
Need to take out Motherboard, problem in contacts PCI with small board near videocard. Reconnect it and clean contacts. it must solve your problem.
If you will need any support with any ultrasound brand, write me.
mike.ross.ultrasound@gmail.com
Good luck)
