The analyzer stuck in "Initializing, Please Wait..."
can not proceed.
Any solution?
Mon Jun 13 2022
Thu Nov 03 2022Reply from Stacio
Hi
I've got the same issue
this is due the lamp needs 6 volts to work, but the regulator that brings this voltage gives only 3 volts.
So I took the 12 volts from the switched power source and using an external regulator I got the 6 volts.
Or better yet, try to find the original regulator and change it.
my mail is stacyroulet@gmail if I can help you.
