What is the Channel Error Code 13-1064-1229?
Mon Jun 27 2022
Error Code
Thu Jun 30 2022Reply from MapleTreeBiomed
Hey JVP,
The Alaris hardware error codes are a three digit number then a four digit number. Eg XXX-XXXX. What you have is a software issue. Your best best is to re-flash the machine if you have the software to do so.
Wed Jul 06 2022Reply from jvp
I figured out that the serial # saved to the PCU was incorrect, so I updated the S/N and re-flashed the unit. It worked. Thanks for the reply.
Thu Sep 08 2022Reply from chrystalligon
