The device was recently calibrated but it needs to be moved to a new location. Will it need to be re-calibrated or are there other steps to follow?
Mon Jul 18 2022
New Location Setup
Tue Jul 19 2022Reply from jrreyes
You do not need to recalibrate. It can simply be moved. Ensure you keep the system standing up while its being moved. Then just turn it on at the new spot.
Tue Dec 12 2023Reply from eira jeremy
Moving the calibrated device to a new location may require re-calibration. It is recommended to follow the manufacturer's guidelines or consult a professional to ensure accurate readings and performance after relocation.
"my location now" help you locate
