Trying to repair my co2re. The aiming beam is not centered properly. I've got the thing opened up. Any advice on aligning the aiming beam properly? I'm having a tough time...
Josh@thelaseragent.com
Equipment: Syneron-Candela - CO2RE
First question: Are the aiming and treatment beams coaxial?
Second question: If they are, does the aiming beam stay normal when the arm is moved around? ("Normal" meaning not diffracted.)
With the arm off, perform a near/far alignment of the aiming beam conforming it to the treatment beam, and you'll be good to go.
I am having the same issue, however when my aiming beam is moved around the beam does not stay "normal".
