Faulty buttons
I meant that the voltage on the buttons in working condition should be 1.2 volts. Is it possible to enter the BIOS on this ultrasound machine?
Problem solved . It turned out that on the internal electronic board in different places failed miniature pass-through inductors, through which the digital signals from the connectors come to the microcontroller or to another connector. I soldered them, replaced them with 20 Ohm resistors, and after that the machine worked.
