Wed Jan 26 2011
display calibration
What are the steps to calibrate the touchscreen on MP70?
Wed Jan 26 2011Reply from GaryBiomed
GaryBiomed
I also uploaded the service Manual [url=http://photos.medwrench.com/manuals/2354-1522.pdf]service Manual...[/url] Touchscreen Calibration To access the touchscreen calibration screen: 1 Enter service mode 2 Select Main Setup 3 Select Hardware 4 Select Touch Calibration To enter service mode select Operating Modes in the main menu. Then select Service Mode and enter the password Passwords In order to access different modes within the monitor a password may be required. The passwords are listed below. Monitoring Mode: No password required Configuration Mode: 71034 Demo Mode: 14432 Service Mode: 1345 Consult the configuration guide before making any changes to the monitor configuration. Disabling/Enabling Touch Operation There are two ways to disable/enable touchscreen operation: 1 To temporarily disable touchscreen operation of the monitor, press and hold the Main Screen key. A padlock symbol will appear on the key. Press and hold the Main Screen key again to reenable touchscreen operation. 2 To permanently disable touchscreen operation: a. Enter Service Mode. b. Select Main Setup c. Select User Interface d. Change the Touch Enable selection to no. To re-enable touchscreen functionality change the Touch Enable selection to yes.
Wed Jun 29 2022Reply from JUAN ANDRADE
TANK YOU GARY
Sun Feb 02 2025Reply from hulmeville
Hi. Could you contact me regarding a question about the mp70 invasive cable.
