Equipment: Fujifilm - FCR XG1
RU will not read IP - image white
Unfortunately I cannot help you at the moment. But in case you could provide the application software for the Fuji I eventually could reactivate my Fuji XG1 CR-IR 346RU
Thank you Hermann for the reply. This post was created in October '22 in desperation to get the unit working again - just in case anyone out there knew of a fix. That did not happen so I had a tech come in - he could not repair the unit (replaced the main CPU board) so we decided to retire the unit and move onto a more modern technology. So we cna close this thread as my trusted RU unit is in retirment,
Geert, thank you for your instant reply. As I am desperately searching for the application program my question is whether your retired equipment is still available and the harddisk with the program could be found. In that case it would be great to have the harddisk cloned! Thanks a lot.
