F32 error clear
Equipment: Shimadzu - MobileArt Eco
The normal Mobile Art the F32 error means: Measured filament current is more than 50% lower than the set value. You can try clearing it by turning the system off and resetting the main breaker. You could also make sure your batteries are charged and in good health. Most likely you will need to do a filament calibration.
