I have a 9800 that will not line up to the home position after reboot. I can place a screw driver on the II and take a picture and the tip of the screw driver will be at the 2 oclock position instead of the 12 o clock position on the monitor (the screw driver is aligned to the mark on the side of the II).
* The home position is set in the work station.
* I have looked at the camera and do not see any loose gears or stripped gears.
* I have calibrated the camera stops (CW rotation =801, CDW rotation = 3).
* I reseated the connectors at the camera.
* The camera can rotate CW and CCW without issues.
I have read and read and cannot find a procedure to calibrate the home position and assume it would be an electronic value between the CW and CCW cal points.
Any help or tips would be appreciated.
Equipment: GE Healthcare - OEC 9800
