Equipment: Fujifilm - FDR Go
at full drive speed - power to the mtrs drop out and back on. Causing the Wheels to studder. Any suggestions.
RE: DR Systems Report Post
Hello, if You think it's electronic fault please, try to describe that mtrs definition to me and I can help you.
michael1234
The mtrs run on 120v at full speed (speed setting at 70) but voltage drops drastically then jumps right back up to the 120v. This is what is causing the studdering. At slow speeds (Setting 40) the mtrs run smooth. All voltages going into the MUX Diver 7 board look constant when driving. (Wheels offthe ground). 120v, +5v, +3.3v, +1.2v, and the 24v. Also the 120v to 15v drive control seems steady.
Hello Fishslayer, then, you need to see the driver from motor and I ask also, how many years have machine? If a few years, then you need to see some capacitors from electronic driver board because if they are not working correctly cause ripple efect when accelerate then take more amperes and frequency change so, you will need to see the wave form. If I am mistake Ibeg apology.
michael1234
