Equipment: Toshiba - Xario XG
License Key
Hi, what are the 14 characters displayed? You probably still have the ones from 2022.
For 2023 it will be a new string of 14 with a new password of 6 characters.
Check also what date your unit is at right now. I can supply you with any of the old License strings and Passwords from 2003 to 2022, I don't have the one for 2023 yet.
Hi MarioLM!
The machine was serviced in 2022, so I would imagine its at 2022?
Here's the 14 digits:
BF94F011E99226
Thank for your help!
Hi again, that is the 2022 License string and the Password is F8C661, but if the date on your display is 2023 you will need the new license string and password, which I don't have yet. But you can still just change the time with the procedure I sent you on Medwrench.
Press MENU KEY on console
Select SYSTEM SETTING on screen
Select GENERAL PRESET on screen
Change time on screen
Select SAVE on screen
Thank you for the time change info! It worked!
Now, as far as the key, I put in what you gave me and the system said I "must provide a valid license key to acess the system." I tried multiple times and made sure it was capitalized.
