Tue Jan 10 2023
Changing ETC02 setting from % to mmhg
I need to change the ETC02 settings from % to mmhg .
Equipment: Datex Ohmedal Cardio Cap 5
Wed Jan 11 2023Reply from MapleTreeBiomed
MapleTreeBiomed
Hey Harryb181,
Try after letting the monitor boot up fully.
Find Monitor Setup –> Install/Service (password 16-4-34) – Installation – Units – Parameters. If it's an option it should be there.
Otherwise, maybe make a cheat sheet? Find the ambient atmospheric pressure at your facility in mmhg and multiply it by the displayed percentage? So 760mmhg (pressure at sea level) * 5%= 38mmhg
Good Luck!
Wed Jan 11 2023Reply from Chris S
Chris S
It should be as follows:
  1. Press the ComWheel and select Monitor Setup from the main menu
  2. Select Install/Service and enter 16 - 4 - 34
  3. Select Installation
  4. Select Units
  5. Select Parameters to review and/or change the units for a specific parameter.
  6.  Save changes in the Save Modes Menu using password 13 - 20 - 31
Chris S
  1. duplicate
