I got error 4021 from Siremobil Compact L with Memoskop CX,
The text appear on monitors.
The memoskop function CTRL+T, CTRL+U work with generator connected.
I have checked the X10 'main umbilitcal cable' connection pins for damage/bent over, and none of the pins are pushed-in, a couple of pins are partly-in, this is normal.
I have checked the cable wires between the X10 & Memoskop in case a wire is broken.
I tried to Memoskop, Technical setup, menu "Diagnostics" - "Erase Harddisk" but doesn’t has “Diagnostics” menu, Please advice.
Best Regards,
Chao.
Sun Mar 26 2023
Error 4021
Sun Mar 26 2023Reply from outinleft
The message "minimum mode" should show on the monitors for about 30-60 sec. after booting. Does it disappear after about 30-60 sec. as it should?
Wayne Horsman
Columbia Imaging
wayne@columbiaimaging.com
Mon Mar 27 2023Reply from Chaovalit
Mr.Wayne Horsman, Thank you for your kindly support.
The message "minimum mode" doesn't show. It looks normal.
My last try, I swapped the memoskop to another unit that the error follow to other unit (I try quickly cause I have 10 minute allowed from my customer to try.)
Best Regards,
Chao.
Mon Mar 27 2023Reply from Emily Vitkovitsky
Agiliti: https://www.medwrench.com/service/companies/agiliti-295
Smart Choice Medical : https://www.medwrench.com/service/companies/smart-choice-medical-usa-llc-290
Sat May 06 2023Reply from lorde
Mon May 08 2023Reply from outinleft
