Sun Mar 26 2023
Air mattress not inflating
Bought used. Initially is was difficult to get air mattress to initiate but with persistence something happened and it worked great for 1 day. At the end of the first day it was unplugged. Day 2 powered up and it will not inflate whatsoever. Not on max inflate or the other option. It also will not turn or perform percussion which it absolutely did on day 1. Any advice would be appreciated
Equipment: Hillrom - TotalCare SpO2RT 2
   RE: Bed Report Post
Mon Mar 27 2023Reply from Emily Vitkovitsky
Emily Vitkovitsky
If you are in need of immediate assistance please feel free to reach out directly to our sponsors. They are happy to help. Integris Equipment : https://www.medwrench.com/service/companies/integris-equipment-239 MERCO Biomedical : https://www.medwrench.com/service/companies/merco-biomedical-269 Just be sure to tell them you were referred by MedWrench
Mon Mar 27 2023Reply from Ray Brown, CBET
Well, if the air pump is not running at all, it would seem that you may need to replace it. It's not terribly difficult to get to and replace, but you'd have to buy a replacement pump first, and all I can suggest is that you can goggle for a TotalCare air pump. New pumps from the mfgr. can be around $600, if they would sell one directly to a consumer. But the pump has 2 pairs of wires which you can measure what's going on. I believe the pump has 120 VAC on it all the time. The controlling section will put from 0 VDC to 12 VDC into the pump to go from zero to full speed. You can check if you have the voltages there. If you do, new pump time. And everything is Torx like T20 and T25. Good luck.
Mon Mar 27 2023Reply from Chris-CBET
Let's start at the beginning, terminology makes a difference. Is your pump running? Does it make noise, do you feel air flow? Have we verified power to the pump unit yet? Or is it just the your mattress isn't filling? Is it fililng partially or not at all? Could there be an air leak?
Mon Mar 27 2023Reply from Anthony Stymest
There is absolutely no air flow. Initially when I bought it I had to keep playing with the screen “max inflate” and nothing would happen. Suddenly it started working. The pump was running, max inflate was working, percussion therapy was working beautifully. I unplugged it and moved it the next day. When powering it up the air pump does not work, no noise coming from it, not even a humm.. the computer screen shows max inflate and percussion therapy but nothing is happening. I did not verify any power to the pump yet.
Thu Mar 30 2023Reply from Anthony Stymest
Ray brown- you were EXACTLY right. It was the air pump. It’s working beautifully now. Thanks for sharing your knowledge. This has helped me more than you know. This is a bed for my bedridden mother. She sends her love too! Thank you!
